Xt 600 3TB 4PT?
rachub48
Xt 600 3TB 4PT?
Post autor: rachub48 »
Witam, mam yamahe XT 600 3TB 1996, ale na niektórych elementach jest oznaczenie 4PT. Tak ma być? Czy może części pochodzą z innego modelu?
Jeśli jest ok, co oznacza 4PT?
dzięki za odp
rachub48
Re: Xt 600 3TB 4PT?
a więc znalazłem coś takiego, co prawda w języku ang
XT600E differences.
3TB 89-96
4PT 96-06
**95/96 4PT1 model looks like a 4PT but uses the old 3TB engine with L/H/S clutch cable entry**
Major differences, starting at the front.
4PT had a larger diameter brake disc. (but uses the same twin piston 3TB caliper) The 3TB disc had 6mm fasteners – The 4PT, 8mm.
4PT had a rev counter, as did all other XT550/600 models. The 3TB was the only model without one.
3TB & 4PT Top yoke/ignition switch different
3TB & 4PT tank/seat/side panels/tail piece - different, but interchangeable as a complete set.
4PT2 onwards uses an engine that has the old XTZ660 type clutch actuator mounted on the top of the clutch cover rather than using a pushrod actuated from the left, as all other XT550/600 models used.
3TB/4PT shock/linkage/swingarm/brake/rear wheel are essentially the same.
